LTA or LTZ
Old Dec 19, 2008 | 01:19 AM
JIm43212002's Avatar
Default LTA or LTZ
I just boaught an 2002 50 Suzuki with no plastics engine runs well but, How can I tell if it is an LTZ or an LTA? Does the 2 stroke run off mixed feul or pull form an oil tank?
Old Dec 19, 2008 | 10:27 AM
murox's Avatar
Default LTA or LTZ
Well since it's a 2 stroke you want to premix a 2 stroke oil with gas, I'm not sure the ratio you want, but it will be between 32:1 and 50:1 most likely. To mix this properly you will need a ratio rite cup, they are made to help you mix. If you don't have one, a little thing from the kitchen, a container that measure to "1 cup" will get you a 32:1 ratio in a 2 gallon fuel container.
Math: 2/32 = .0625 gal 2 stroke oil. .0625 gal 2 stroke oil = 1 cup 2 stroke oil.
About identifying the model, I'm not sure. Some of these guys who know how to decipher the VIN code, which should be somewhere on the machine, maybe on the frame.
Old Dec 19, 2008 | 10:39 AM
LT80's Avatar
LT80 Expert
Default LTA or LTZ
The LTZ is a 4 stroke.
Your 50 has a oil tank for the 2 cycle oil. It's an auto injection system. You do not need to pre-mix unless it's been converted to do so.
Old Dec 19, 2008 | 01:23 PM
4strokemurder's Avatar
Default LTA or LTZ
you should be able to tell by sound, 2 stroker are more of a weed wacker sound. [img]i/expressions/face-icon-small-happy.gif[/img]
Old Dec 19, 2008 | 03:17 PM
onebigzj's Avatar
Default LTA or LTZ
<div class="FTQUOTE"><begin quote>Originally posted by: 4strokemurder
you should be able to tell by sound, 2 stroker are more of a weed wacker sound. [IMG][/IMG]</end quote></div>
but what if he has a four stroke weedwacker. he will be so confused[img]i/expressions/face-icon-small-confused.gif[/img]
sorry had to
Old Dec 20, 2008 | 03:54 AM
Default LTA or LTZ
Thanks for the input. Is does sound like a four stroke, So im pretty sure it is the LTZ but there is an oil tank just under the seat, I plan on tearing into the bike this weekend, replace the spark plug, change the oil and put a new pipe on it.
Old Dec 20, 2008 | 11:36 AM
LT80's Avatar
LT80 Expert
Default LTA or LTZ
They did not make a 4 stroke in 02
