Need Help with my Uncles King Quad
Old Dec 25, 2008 | 03:22 PM
99GrandHero's Avatar
Default Need Help with my Uncles King Quad
My uncle was riding his 99 KQ and hit a tree, still ran fine, just bent the frame. He and my other uncle stripped it all down, and put it back together on a new frame. Now they cant get any power to the ignition/gauges, no lights, no anything. I got the test light out and traced most of the wiring not finding any problems. I got hung up when i found that as soon as we turned the key on, it blew the main fuse. We have unplugged almost everything and still blown dozens of fuses with no luck. I'm thinking there is something grounded improperly, and am in need of a full wiring diagram. If anybody knows where I can get this or has one, please let me know...
THANKS!
Old Dec 25, 2008 | 06:34 PM
jaybeecon55's Avatar
Sound advice there. "Hey, watch this........"
Not sure how much good a wiring diagram will do you - you're going to have to trace what you have to find the problem.
Sure seems like you have a normally positive line that is grounded out - either connected wrong or pinched against the frame somewhere. I'd disconnect as much as you can from any power or from the switch, then hook up one at a time until you blow a fuse again, then trace that line.
Jaybee
Old Dec 28, 2008 | 02:25 PM
Yeah thats what we've been doing, we've unplugged just about everything unpluggable and still the fuse pops as soon as the key is turned on. I was wanting a diagram to see if everything had been hooked up correctly, Since I wasn't around when they took it apart I have no idea what goes where.
Frisky2050
Apr 9, 2020 11:19 AM
Ashley S
May 29, 2017 10:54 AM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
DOC HOLIDAY
Jul 9, 2015 01:09 PM
D-Hagz
Jul 4, 2015 02:19 AM
