King Quad 700 reverse sputtering
Old Jan 5, 2009 | 10:59 AM
funky5kq's Avatar
Default King Quad 700 reverse sputtering
My 2005 KQ700 sputters while in reverse and does not have much power in reverse. Forward, it runs like a champ! Any ideas?
Old Jan 5, 2009 | 06:06 PM
jaybeecon55's Avatar
Sound advice there. "Hey, watch this........"
Maybe a dumb question but you are using the reverse overide aren't you? If you are than maybe you have a bad override switch.
Jaybee
Old Jan 5, 2009 | 06:20 PM
funky5kq's Avatar
I am not using the reverse overide. Never have.
Old Jan 5, 2009 | 10:24 PM
<div class="FTQUOTE"><begin quote>Originally posted by: funky5kq
I am not using the reverse overide. Never have.</end quote></div>
Well, that's what it's for. Throttle in reverse is limited - give it too much throttle and it will sputter and run rough. But, for those short periods of times when you need more reverse throttle you have the reverse override. Hold it while in reverse and you'll have more throttle without the sputter.
At least, that's how it *should* work. When the early model '05 KQ's had their bushing seizing problem a part of the "fix" was to limit the reverse overide. But even if your model got hthe'fix' it should stiill have more power in reverse if you use the overide.
Jaybee
Old Jan 6, 2009 | 09:13 AM
funky5kq's Avatar
Learn something every day. I'll see what the difference is. Thank you.
Reactant
Mar 30, 2022 02:08 AM
Frisky2050
Apr 9, 2020 11:19 AM
Scottma518
Jul 10, 2015 12:42 AM
DOC HOLIDAY
Jul 9, 2015 01:09 PM
D-Hagz
Jul 4, 2015 02:19 AM
