suuki 85 Lt 50
Old Jan 14, 2009 | 04:12 PM
bogdown's Avatar
Default suuki 85 Lt 50
ran fine shutoff went to restart would not start,getting spark and fuel wont even try to start.any suggestions?
Old Jan 15, 2009 | 06:08 PM
Burke753's Avatar
If the plug has any black on it try a new plug and see if that works. That is the only way I get mine to start sometimes
Old Jan 15, 2009 | 06:59 PM
bogdown's Avatar
tried new plug still would not start.spark is good,bike wont even try to kickover.
Old Jan 15, 2009 | 09:58 PM
Burke753's Avatar
By not trying to kick over do you mean that the engine won't spin and your pull start won't even move? In that case the engine is seized, also if your pullstart pulls out and it just won't fire you might not be getting any fuel or have a bad air fuel mixture so it won't ignite
Old Jan 15, 2009 | 10:14 PM
kamikaze1a's Avatar
Is your sparkplug wet or dry? If plug not wet, pull boot from airbox side of carb and very carefully squirt a little fuel into carb and then try starting. If it starts or tries to start, then either you are not getting fuel to the carb (bad petcock, no fuel in tank, plugged fuel filter etc, bad/plugged needle seat, pinched hose) or choke not working. If it still won't start, your spark may not be strong enough. You might try closing the sparkplug gap to .020 or so just as a test. That smaller gap will help IF your spark is weak.
If all else fails, try taking a compression test. And all this is assumming that your engine cranks (turns) when you hit the starter...
Old Feb 17, 2009 | 09:05 PM
springer06's Avatar
had the same problem with mine, pulled the fly wheel off and found out the crank seal was bad, there fore it wasnt pulling fuel in.
Old Feb 19, 2009 | 08:17 PM
Budds's Avatar
Try holding the throttle wide open and try starting if fires then choke is faulty or bad mixture. Try draining fuel tank and put fresh fuel in could be stale gas.
Old Feb 20, 2009 | 12:28 AM
jeffturner's Avatar
You need a mechanic for this
js3350z
Oct 14, 2003 07:06 AM
