LTF230G brakes
Recently bought 1986 LTF230G ATV and need to replace rear brakes. The Clymer repair manual says to remove rear axle to replace brakes. Is removing axle necessary or can brake shoes be replaced without removing it. Thanks for any help.....
As I had not received any responses followed manual and loosened axle nuts on left side (I did not remove the spindle) and slid axle to right enough to replace brakes. It was not difficult at all the hardest thing was loosening the axle nuts as they are rather large. I used pipe wrench to loosen them. Thanks for your response...........
oliveiracarlos
Sep 7, 2015 03:39 AM
