what do u think
Old Mar 5, 2009 | 12:19 AM
vinson jeff "03"'s Avatar
Default what do u think
The top of the front rt tire bowing outward, Do u think its A arms or spring and shocks or What. Does it with no one on it too? Any info is a help thaanks
Old Mar 5, 2009 | 08:41 AM
LT80's Avatar
LT80 Expert
Something is either bent or wore.
Grab the tire and try pushing in/out to see if a brg/bushing/etc is wore/loose.
Old Mar 5, 2009 | 10:45 AM
cherokee99's Avatar
if you put weight on the front of the quad does the problem correct?
jack up the front of the atv and check bearings and bushings for wear as well.
if putting weight on the atv corrects the tire issue your shocks are ether too stiff or worn out and need to be replaced
Old Mar 5, 2009 | 10:42 PM
if i pull up on the front rt side of the atv it corrects the problem, i haven't tried putting weight on it. i will try that and the other suggestions too thanks for your input
Old Mar 5, 2009 | 11:48 PM
cherokee99's Avatar
your saying the top of the right tire is bowed out like this? // (excuse my crude picture of backslashes) and if you pick up the front end it corrects?
that sounds like wear in a ball joint or wheel bearing. you need to jack up the front of your atv and check for slop in the tires. if there is slop its wheelbearings, you should replace those as a set. if its ball joints you should replace all 4 of those.
beleave me you dont want to mess around with worn balljoints! i didnt know the lower balljoint on my first atv was bad until i hit 45mph and the tire tucked underneath the atv. it stopped very abruptly and i was nearly thrown over the handelbars onto a concrete colvert... now i check my bearings and balljoints atleast once a season.
Old Mar 6, 2009 | 07:40 AM
shreker08's Avatar
I agree it has to be the wheel bearing or the ball joint
Old Mar 6, 2009 | 08:23 PM
yes like // . not real bad but noticable, when you say put weight on it, you mean sitting on the atv or direct weight on the rack over the tire. if i pull up on the rack it solves its not vary much pull either. my shocks are set at the highest setting because of plowing.
