lt230s cracked case :(
Old Mar 10, 2009 | 11:16 PM
cherokee99's Avatar
Default lt230s cracked case :(
here is another pic for your collection justrandy.... bolt that connects magneto cover to case half broke, buy the chain ofcorce!, and cracked the case half. my spair engine is not rebuildable. [img]i/expressions/face-icon-small-sad.gif[/img] but i think i can scavenge the cylinder for my running 230 instead of resleeving the origional.
it seems kind of stupid that the owner was too lazy to tighten the dang chain. especially since EVERY junction in the frame has been gusseted to keep it from bending! somebody loved it.
Old Mar 11, 2009 | 08:47 AM
UGLY88's Avatar
The chain might have been tightened, however if the pivot bearings and or bolt are worn out, it will cause the chain to come off .
Old Mar 12, 2009 | 11:58 AM
NewportHillClimber's Avatar
mines been like that for years. i just clean and lay the jb weld to about once a year
Old Mar 12, 2009 | 07:25 PM
Stainless's Avatar
I got a root stuck in between the chain and sprocket once because the guard was off and it broke in that same area. Just got a guy at work to weld it up and it worked fine.
Old Mar 12, 2009 | 07:32 PM
thats awesome. if you can get someone to weld magnesium then that the way to go
Old Mar 12, 2009 | 08:57 PM
dealer374's Avatar
That happened to me twice on my 250S. The first was becuase my axel houseing bearings and swing arm bearings were loose. I replaced the axel houseing and added swimg arm spacers because there were none and added bearing cuz there was only 1!! I did this and bought a new case for $90 i found used. Then it happened again because the swimgarm had a chunk missing moving the bearings loose. The time it stayed in one peice instead of breaking. I had a guy i know weld it up good as new and I bought a used swing arm $105 used. and the whole thing is history.
Alex G.
Sep 11, 2017 11:38 PM
EIF
Apr 20, 2017 07:15 PM
Troylee216
Sport Quads
Sep 28, 2015 09:34 AM
WilliamBos
Sep 22, 2015 04:07 PM
