LT250S Bearings
Old Mar 11, 2009 | 01:23 PM
DavidLT250S's Avatar
Default LT250S Bearings
Hey guys hows it goin?? My gf decided she wants to ride with me this summer so i pulled my old suzuki and decided to start fixin it up for her. I went to change the front wheel bearings and cant seem to be able to get then out of the hub. Do i need to press them out or what? I tried taking a large socket and hammering them out but no luck with that. Is there a special way to work with these bearings are any tricks to get it done?? Any info would be great. I wouldnt be suprised if these were the original bearings.
Thanks,
Dave
Old Mar 12, 2009 | 08:24 AM
ah comon somone must know how to take the bearings out of the hub
Old Mar 12, 2009 | 09:20 AM
atvman29's Avatar
I just took old bearings out of some a-arms and it was ridiculously hard. I jimmy-rigged a puller where I could tighten a bolt to pull them out and it took forever, but I got them out.
I couldn't budge them with a hammer.
Old Mar 12, 2009 | 11:57 AM
NewportHillClimber's Avatar
first pop out the inner and outer seals then take a 1/2" rod thats about a foot long and drive it in at an angle from either side of the hub until it catches the bearing on the other side. then move around to each corner of the bearing tapping it with a good hammer until it comes out. then flip it over and do the other bearing. when you put them back in be sure its real clean and if possible press them back in. be sure you put the bearing spacer back in the center of the hub and put in plenty of grease. you may have to hit a few good hard times to get the bearings started
Old Mar 12, 2009 | 09:33 PM
if i put a big socket and hammered on it to get them out will this work or is there somthing in the middle that is not going to move? what is between the 2 bearings?? is it a spacer or somthing and does it come out or is it built into the hub
Old Mar 13, 2009 | 04:12 PM
there is a spacer in between the bearings so youll have to force a rod in at an angle and tap it to get the other sided bearing to loosen so you can move the spacer to one side. each bearing has to come out from its own side
Old Mar 14, 2009 | 09:31 AM
LT80's Avatar
LT80 Expert
HEAT!!!
That'll expand the alum so it's easier to whack em out.[img]i/expressions/face-icon-small-smile.gif[/img]
wendal
Aug 3, 2024 10:03 PM
2quiker
Mar 22, 2022 08:36 PM
exmotocrosser
Sep 13, 2019 06:12 AM
jbrewster94
Sep 23, 2015 04:16 PM
Elkaholic
Sep 6, 2015 02:44 PM
