6000K - Should l replace belt???
Old Apr 1, 2009 | 09:47 PM
BigRedDragon's Avatar
Default 6000K - Should l replace belt???
Gaday....... to all...... - I have a 06 King Quad with 6,000 klm on it. Orginal belt and has lost a bit of top end speed - how much of a diffrence would a new belt make?????
Old Apr 2, 2009 | 10:50 AM
atvman29's Avatar
I'm not a mechanic, but I wouldn't think a belt could take away from your top end. Maybe something needs a little re-tuning? Check your service manual and that should say the mileage when the belt should be changed.
Old Apr 2, 2009 | 11:03 AM
DODGE57HEMI's Avatar
Mopar Man!
As like the belt on your car they need a good inspection (no cracking) if all looks good I would run it and give it a yearly inspection thereafter! Most ATV belts run a metel webbing inside there therfore no streching of the belt to affect top speed. Just out of quriosity when was the last time you did a full tune up? (plugs and valve adjustment)
Old Apr 2, 2009 | 11:08 AM
TLC's Avatar
TLC
Because the belts are cheap and easy to change I would change it for just peace of mind.
I was neck and neck with my consin's 500 Scrambler on top end speed but once he bought a new belt
he could walk away from me on top end.
Old Apr 2, 2009 | 11:58 AM
TorkMonster's Avatar
It depends on the clutching what a wore belt will effect...
Most of them will lose some top end in the range of 3mph-10mph.. And will normally feel extra powerful on the low end....
If it was ME, I would change it, and keep that one for a spare.. Nothing worst than being in the bush with broke belt...
Old Apr 2, 2009 | 06:18 PM
Default Reply
Yes just got a recent tune up on it - everything was in very good shape - only one valve out 4 needed adjustment!!! thx
Cummins Driver
Sep 11, 2019 01:22 PM
toonces
Jul 31, 2015 09:27 AM
toonces
Jul 28, 2015 01:58 PM
Mikesohio
Jul 26, 2015 10:51 AM
trouttracker
Jul 20, 2015 11:54 AM
