08 750 issues?
Old Apr 2, 2009 | 01:52 AM
miskywhisky's Avatar
Default 08 750 issues?
My buddy just picked up an 08 king quad 750 and we've noticed a few things that don't seem right.
Does anyone else have a pretty wicked shaking at about 1/8th throttle? His does so hard you can see the rear fenders flapping. My brute force is a twin and doesn't shake anywhere near as much.
Also we were in the rain and all 3 headlights fogged up on the inside about an inch from the bottom. Now 1, ok a little seal issue but all 3? Thats a bit much.
Does anyone elses do this? We would just take it in but we got a big ride planned for this weekend and don't want the quad stuck at the dealer.
Old Apr 22, 2009 | 08:23 PM
Dizz's Avatar
Default On the shake
On the slightly above idle shake.my 450 has same issue,as I was slowly decendind hill,so much shake I thought I had brake issues,till I figured it out.A slight increase in throttle&it would go away.Any large one lungger has a lotta vibration.even some twins.It has a counter balancer that takes out about all the shake at higher normal engine rpm`s.Their is a "spot" in the rpm range that it will still show(shake) thru,and is at slightly above idle on the KQ.My Honda 300 didn`t have this issue,buw was a little buzzy all the time,not bad though.
Just my idea,but sure it`s correct.
No ideas on lights,just check seals.
regards,Dizz
COFatboy
May 2, 2020 12:06 AM
Jenn1
Sep 8, 2015 09:16 AM
Findlay Tulloch
Aug 25, 2015 05:00 PM
WesTech
11
Aug 11, 2015 07:55 AM
Unzzy66
Jul 11, 2015 10:01 PM
