Suzuki lt230s 1988 problem
Old Apr 4, 2009 | 03:06 PM
spededdy's Avatar
Default Suzuki lt230s 1988 problem
I have had this quad for 4 years, no major issues with it, it is a great quad, always runs. last few times i have took it out, i will drive it for a little bit, and sometimes it seems to have no power, only for a bit, then it will kick in and speed away, it does this once in a while, i cant think of whats wrong besides spark plug or air filter, please give me some input thanks!
Old Apr 4, 2009 | 04:23 PM
atvman29's Avatar
Sounds a bit like a clutch going south on you. Does the motor sound any different when it's acting up?
Old Apr 4, 2009 | 04:27 PM
spededdy's Avatar
yes, it totaly dogs down, how do you know its the cluth, and how can i tell?
Old Apr 4, 2009 | 10:44 PM
rockout's Avatar
imo, bogging and sluggishness is usually a fuel issue ( either carb or fuel supply), and a sharp miss or cutting out is usually spark or electronic issues. i would definately check the carb out and petcock. has it been sitting? i have a bunch of old machines and am in the process of restoring them. on one of my dirt bikes, i kinda have the same problem. i finally found gunk in the petcock and it was restricting fuel flow. took it apart and cleaned it. no more problems.
Old Apr 5, 2009 | 09:20 AM
spededdy's Avatar
it hasnt been sitting it just happened one day
Old Apr 5, 2009 | 12:15 PM
rockout's Avatar
i would go through the carb and also drain the fuel tank and check petcock opperation. make sure it doesn't have something plugging it up intermitantly.
Old Apr 6, 2009 | 09:28 PM
spededdy's Avatar
im not sure how to do that, the petcock?
Old Apr 6, 2009 | 09:49 PM
rockout's Avatar
where you turn the fuel on and off. it is called a fuel petcock. also, get a service manual. it will help you out a lot. pictures with descriptions.
Old Apr 6, 2009 | 09:54 PM
spededdy's Avatar
so i have to take the carb apart?
Old Apr 6, 2009 | 10:02 PM
rockout's Avatar
yup
