z400 front shocks
Old Apr 9, 2009 | 09:44 PM
rybo's Avatar
Default z400 front shocks
What do you guys think..I have an 03 z400 and i need to replace the front suspension with something more plush. I found 2 pair. first pair is a 2008 new takeoffs with rezzies. and the second pair is works , new setup for a 190 lb rider (im 205)but they are made for +2 a-arms. The guy selling them said it does not make a differnce because i have stock a=arms. The works are only 150 more than the stock 08's..Thanks Brian
Old Apr 11, 2009 | 10:53 AM
NewportHillClimber's Avatar
if the shocls are made for +2 a arms then they will raise the front of your z real high if theyll even fit. call the guys at works performance they are really helpful. just tell them what you want to do with it
Old Apr 23, 2009 | 07:56 PM
mucky's Avatar
If they're for +2 arms the shock is the same in length, the springs will be set different. I know I had to send my elka's in to have different springs and have readjusted for the +2a-arms I installed, anything over +3 requires longer shocks, one good thing about the 08 shocks is they are ajustable, works are great shocks, call them and ask for info
Old Apr 25, 2009 | 12:05 AM
hotblooded's Avatar
Yep, if they are standard travel shocks and are on a +2 arms they will work but will be too soft when put on stock arms. You could prolly get by setting the springs heavier. I have a set of works on a Blaster and was told that they are pretty much a throw away once they get worn out, one thing though is you can make a works a rezzie shock and really brings them to life.
Bratman2
Aug 6, 2022 01:42 AM
07Redrider400
Jul 25, 2015 05:31 PM
Jul 15, 2015 02:07 AM
1966F100
Jul 12, 2015 03:08 AM
cSchwartz
Jul 9, 2015 02:40 PM
