08 LTZ 400 start problems
Old Apr 19, 2009 | 03:19 PM
sierra308's Avatar
Default 08 LTZ 400 start problems
My boys 08 LTZ 400 will start with the choke on and idle fast,as soon as you touch the throttle it stops.if you mess with the choke and give it some gas slow it will rev up some and back fire,then quits.Could this be a throttle position sensor problem?A month ago the choke cable came unhooked at the lever,hooked it back up and it was very hard to move,also noticed it did not move as far as before.found corrosion where it goes inside the carb.cleaned this out put everything back together and it ran fine for about a week.then all at once it started backfiring and was hard to start.can anybody help me out?
Old Apr 19, 2009 | 03:30 PM
DODGE57HEMI's Avatar
Mopar Man!
Sounds as if the carb needs a rebuild but I find that kinda odd for a 08 already. Well if all else fails you can pick up a new carb for 350.00 from bike bandit. Sorry I am not much help!
2008 Suzuki ATV Parts for LT F400, OEM and Aftermarket at BikeBandit.com
Old Apr 19, 2009 | 07:34 PM
lt230sman's Avatar
if you go with the aftermarket route, check out sudco, they can hook you up with a carb for CHEAP.
Old Apr 19, 2009 | 07:36 PM
lt230sman's Avatar
also, being on 08, wouldnt your warranty still be of some help? (i have oldschool bikes and have no idea how those waranties work nowadays)
but of course, give the carb a good cleaning and rebuild before you drop alot of money into it.
Yamaha_
Utility ATVs
Dec 16, 2022 07:49 PM
generalpops
Jun 5, 2015 08:23 PM
garyt1975
Jun 5, 2015 08:53 AM
generalpops
Jun 3, 2015 08:25 PM
1000gade
May 27, 2015 12:37 PM
