4x4 Problem/sound
Old Apr 21, 2009 | 04:25 PM
alrab23's Avatar
Default 4x4 Problem/sound
02 Vinson Auto, I put new tires on it, ITP 26/10/12 on the front and I also replaced a bent swing arm..Now when I turn it kinda sharp in 4x4 it makes a popping sound. Any Ideas?
Old Apr 21, 2009 | 04:29 PM
muddyvinny's Avatar
where the cv joint is connected with the rim could be connected loose. does that tire still get power when fourwheel is engaged?
Old Apr 21, 2009 | 04:32 PM
alrab23's Avatar
Yes it works fine just has the noise
Old Apr 21, 2009 | 04:36 PM
muddyvinny's Avatar
most likely it is loose. try taking your rim and tire off and give it a look. but it doesnt pull one way when your riding does it?
Old Apr 21, 2009 | 04:46 PM
alrab23's Avatar
No it doesnt pull any, it used to real bad when the bent swing arm was on there. I will give the cv joint a look first chance I get. thanks for the replies
Old Apr 21, 2009 | 04:48 PM
muddyvinny's Avatar
no problem man..hope you fix the problem.
Old Apr 21, 2009 | 07:56 PM
shreker08's Avatar
are your tires rubbing anythng i mean if it didnt do it before you did the tires could be something to think about
Old Apr 21, 2009 | 08:54 PM
rockout's Avatar
are those the same tires you had on before? i put on 26's and when i turn sharp, they just catch the fender and make a clicking noise. scared the crap out of me, but once i looked down and saw what it was, what a relief. other wise, something like stated before with the axle to wheel or front end part is still loose. check everything you loosened up.
Old Apr 21, 2009 | 09:24 PM
alrab23's Avatar
They are different tires than before, but the noise doesnt sound like rubber to plastic. It sounds like metal poping, more of a high pitch ding.
