New suzuki 230 quadsport
Old May 13, 2009 | 09:03 PM
mdsuave13's Avatar
Default New suzuki 230 quadsport
I just had a 80's kickstart chain drive suzuki 230 given to me. It had a broken control arm (which i've welded back together, had some broken plastics that i had to repair and it doesn't start.
I have gotten it running from push starts, but it wont fire up from a kick unless you have had it previously running and kick the hell out of it with gas involved.
It won't idle either. I have pulled the carb, rebuilt it with a rebuild kit and cleaned everything, still no luck.
I haven't really worked with the mikuni carbs a lot and was wondering what i should be looking for to try to get this thing to fire up from a kick.
Thanks everyone!
Old May 13, 2009 | 09:33 PM
mdsuave13's Avatar
also, i am looking for information on what the valves should be set to? it has to be valve, carb or ignition related. Anyone have the #'s on where the valves should be set to?
Old May 14, 2009 | 01:13 PM
firstgen89sho's Avatar
I would start looking at your valve adjustment, and possibly a worn out intake valve, I had that problem with my LT-4WD, did the exact same thing, had to pull start it, it would start when warm, after, and it turned out to be a worn intake valve.
Old May 14, 2009 | 02:50 PM
mdsuave13's Avatar
thanks firstgen, i will have to pull the valve cover and inspect it for wear. Anyone know the specs for adjustment?
Old May 14, 2009 | 04:12 PM
I do not have the specs on me at the moment, but I am sure if you search through the Quadsport thread, you would find them in there.
As for checking the valves, you need to remove the round caps on the valve cover, as the valve cover is also the camshaft carrier, and rocker carrier, so once it is removed, the valves are closed, and the camshaft is free to move.
Old May 17, 2009 | 08:11 AM
NewportHillClimber's Avatar
its definately a compression problem. i would rebuild and be sure to hone cylinder. then lap valves and you should be good to go.
Valder
Nov 28, 2020 07:38 AM
fd24
Jan 16, 2019 08:59 AM
VABrute
Jan 6, 2016 07:39 PM
merryman
Sep 19, 2015 03:15 AM
Sep 1, 2015 11:59 PM
