05 Eiger petcock fuel valve question
Old May 17, 2009 | 08:52 PM
Phil05Eiger4x4's Avatar
Default 05 Eiger petcock fuel valve question
fuel valve is now bad will not flow right on the ON position but will run on PRIME being that its always flowing. is it ok to run it on prime all the time?? the darn thing is 65$ new. i am going out riding this weekend and just wondering if its ok to ride on prime for at least the weekend if not always so just let me know thanks guys
Old May 18, 2009 | 07:28 PM
jaybeecon55's Avatar
Sound advice there. "Hey, watch this........"
It's not going to hurt it to run on "prime" but it will tend to leak fuel if you keep it there.
Does it run on "Res"? Could be it's just clogged, Eigers are known to have some issues with small pieces of plastic in the fuel system.
Old May 18, 2009 | 09:31 PM
havnt tried it on RES where will it leak out on PRIME at ?
Old May 20, 2009 | 05:26 PM
nextel9's Avatar
The prime just allows fuel to fill the bowl. In the on or Reserve mode, fuel will not flow until there is vacuum from the carb. It has a fuel pump in it. I found that out the hard way, see my post on "Eiger wont run after water". Odd place for a fuel pump, but it is what it is.
Old May 20, 2009 | 08:27 PM
alrab23's Avatar
I had petcock problem like this on my suzuki bandit(motorcycle) the mechanic that fixed it told me it was fine to ride with it on prime just to be sure and turn it back to on when I was finished riding. If not it will fill the bowls.. Mine would run on reserve part of the time and when it started to cut out I would reach down and switch it to prime and it would fix it.
Old May 20, 2009 | 08:47 PM
nextel9's Avatar
What kind of carb did you have on that bike?
Cole Hadden
Jun 15, 2025 09:05 AM
slowgsxr97
Mar 18, 2022 03:40 AM
hondarider1234
Jul 21, 2015 11:53 PM
Aitch
Jul 21, 2015 09:40 PM
Unzzy66
Jul 11, 2015 10:01 PM
