LT-50 FUEL/OIL MIX and TUNE SPECS
Old May 29, 2009 | 12:50 AM
Maverick64857's Avatar
Default LT-50 FUEL/OIL MIX and TUNE SPECS
I have a SUSUKI 2 STROKE Model LT-50 ATV made in DEC. 1985. Originally designed with an OIL INJECTION system that has been removed and plugged. It runs pretty fair on 8 oz. 2 stroke OIL to 5 gal. of 87 Octane GAS but won't start when cold unless it has a shot of B12 carb cleaner down the carb inlet. Does the FUEL MIX sound right? Spark Plug GAP is .030. Is this the CORRECT GAP? The CARB has 2 adjusment screws. One is bronse slotted and is located near what looks like the old OIL INJECTION inlet (INLET PLUGGED). The other ADJUSTMENT SCREW is steel Phillips and NEITHER screw seems to have much effect when adjusted. In fact, it runs with BOTH SCREWS CLOSED! HOW do I adjust FUEL/AIR MIX and IDLE SPEED? Does the IGNITION have POINTS? If so, WHAT is the CORRECT GAP?
Johnny Mac
Aug 15, 2019 03:13 PM
raman8tor
Sep 20, 2015 07:35 AM
Elkaholic
Sep 6, 2015 02:44 PM
