help lt230s
Old Jun 1, 2009 | 07:08 PM
afd2323's Avatar
Default help lt230s
i have a 86 lt230s ,new rebuilt in the carb, starts first kick, idles fine but will not take it under load ,i have played with the screws but no matter how i turn the screws it runs the same, you hit the gas and it boggs and pops,,put the clutch in and it will rev up mint pop the clutch and it boggs, help me please i have dealt with alot of different things on the atv's but never dealt with this,,,
Old Jun 1, 2009 | 07:23 PM
91Warrior357's Avatar
so it bogs and pops in every gear? and with any amount of throttle? but yet it revs up fine? it could still be something within the carb, a spec of dirt somewhere...
Old Jun 2, 2009 | 04:04 PM
afd2323's Avatar
no dirt,i put new plug in and it turned black, so its to rich, i adjusted the big needle as low as it can go still no difference,
Old Jun 2, 2009 | 05:05 PM
lt230sman's Avatar
hey and welcome to the forum!
sounds to me like youve either got the wrong needle or too rich of a main jet.
Old Jun 4, 2009 | 07:51 PM
JustRandy's Avatar
Playing with screws won't do anything but adjust the idle. How is the spark plug? Put a new one in first thing before doing anything else. Can't think of how many times I almost tore into carbs, but first tried a new plug and saved myself hours of screwing around. Plugs go bad for no reason, seemingly.
Next, verify air filter and exhaust. Those affect carb tuning.
Next, check valve lash and verify you have decent compression.
If all that checks out, then start monkeying with the carb. I can't imagine why the carb would suddenly need adjusted unless you did something.... Like a new pipe or different air filter or took the airbox lid off.
Old Jul 26, 2009 | 10:19 AM
afd2323's Avatar
it has a new plug, great compression ,timing checks out,,,plug is black i know that means rich but why, i rebuilt the carb with a stock rebuild kit,,i bought the machine as is with the carb apart in a box, so i have no idea what was done to it, i saw that they drilled a lot of holes in the air box lid??head gasket?? no matter what i do i still only get 1/4 throttle ,,
Old Jul 26, 2009 | 11:49 AM
afd2323's Avatar
ok i found the jet that i took out and yes the one they sent me was to big way to big so i put the jet it calls for (112.5) back in it with the needle,,runs alot better but it still wont open up, if i let it idle and then take off it goes good for 10 seconds and then boggs -no top end, if i dident know any better i would say it is sucking up the gas and the bowl is not filling fast enough, i check and it fills good but kinda hard to tell what it is doing under load, at one point in second gear i just held it and it was acting like it wanted to come out of it but it would not, is the stock jet to small or,
Old Jul 26, 2009 | 03:29 PM
bashr52's Avatar
Did you check your float height?
Old Jul 26, 2009 | 04:26 PM
afd2323's Avatar
i have, and have tryed to play with it , this is driving me crazy, the atv is tight and i have always wanted a small quad to beat on, i just dont know i would say its a fuel problem but not sure ,i dont know if the firing is off or is the timing of by one tooth or would one tooth make any difference,
Old Jul 26, 2009 | 10:56 PM
bashr52's Avatar
One tooth on the cam gear would make a difference depending which way it was off (advance/retarded).
