92 lt2504x4
hey im new here and after doing alot of reading I have come to the conclusion that I am rebuilding my lt2504x4 I just got it and it is smoking real bad but runs otherwise great the guy I got it from said it was just rebuilt profesionaly and shortly after started to smoke I gather im going to have to bore the cylinder have the rod and rod bearings done and buy a piston and rings and a gaskets set but before I open the engine does anyone have an electronic manual for this quad
you said it was rebuilt though right? if the rings are bad already then somebody musta messed up lol, or maybe they didnt hone the cylinder or something like that, i just assumed that they did a rebuild and maybe forgot to check the valves out...either way you can check those out to if you tear it down.
