How do i get the chocke cable out of carb?
Old Jun 5, 2009 | 11:41 PM
PTG's Avatar
PTG
Default How do i get the chocke cable out of carb?
Can anyone tell me how to remove the choke cable from the carb on an LT160 (1989 if that makes any difference)?
Thanks,
Phillip
Old Jun 5, 2009 | 11:51 PM
91Warrior357's Avatar
usually you have to pull out on the choke then take the bolt 13mm or something lose from the base then you should be able to pull it out.
Old Jun 9, 2009 | 12:44 AM
PTG's Avatar
PTG
Default Choke update LT160
Thanks for the tip.
Tried that but the choke was stuck like it was never coming out - hence why the question.
Had to get a butane torch and apply a little heat then it popped out with moderate force.
Thanks.
Phillip
GregM
Mar 6, 2018 06:53 AM
Aitch
Jul 21, 2015 09:40 PM
timster911
Jul 13, 2015 01:57 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
