89-90? quadrunner 300 4x4
Old Jun 27, 2009 | 10:17 PM
sportsmandiesel17's Avatar
Angry 89-90? quadrunner 300 4x4
i just got a 89-90? suzuki 300 quadrunner or kingquad but i have no electrical power. now the battery and wires are very croted but could that be my problem? Its sat for a year in a barn with nothing doen to it and the engine is moist with what it looks as if theres oil at the top of the cylinder.i have no idea caue i'm used to working on polaris's but i got this for free so i couldn't resist it.I NEED HELP!
03 poalris sp 400
04 poalris sp 600
04 honda trx 400
89-90 quadrunner 300
Old Jun 27, 2009 | 10:20 PM
lt230sman's Avatar
well the first thing i'd do is pull off the battery connections and try to jump start it with a car or lawnmower or something like that.
chances are, if its been sitting for a year, the battery just went dead by itself...
Old Jun 28, 2009 | 09:23 AM
ya i put a new battery in it and now its making a clicking sound from under the front end. i don't no wher the starter is on the bike but it can't be in the front end cause thats not where the engine is. right? it has a new spark plug and i cleaned up the connections but the starter needs help. do u no where the starter is
Old Jun 29, 2009 | 08:42 PM
cvanwyngarden's Avatar
If you're getting a clicking noise from the front end, it almost always means that you have a bad connection to your battery or a dead battery. Try cleaning all the corrosion off with a wire brush, and some baking soda and water, and then try again. The clicking is just the starter relay not getting enough power to stay closed. I'll bet once it's cleaned up a little, it'll turn over just fine, as long as your engine is free
Old Jun 30, 2009 | 05:11 PM
ya i did work now but i still have no spark.a person told me to look at the mags imbehind the recoil but that is a huge job.i got a new coil and checked the kill for colts and it seems fine but i still have no spark. i person also said something aboutthe CDI box but i don't no where is it so do you no where is
Old Jun 30, 2009 | 05:53 PM
cvanwyngarden trudges off and gets his LT-4WD Service Manual...
From the pictures regarding the CDI Unit in the service manual (Page 6-3 if you have one), it looks like the CDI Unit is on the front right side, just where then black fender meets the plastic. It looks to be a small black box, held on by 2 screws, and has 2-3 plugs sticking out, and will likely have a Black with red tracer wire, a White w/ blue tracer, a Black w/ White tracer, and a black w/ Yellow tracer.
Hope that helps!
Old Jul 1, 2009 | 11:15 AM
ya i called a good friend of mine and said its rarly the cdi box but it could be the relay cause there pretty common
Dammar
Apr 20, 2016 06:03 AM
phummer3210
Sep 11, 2015 03:47 PM
Sep 1, 2015 11:59 PM
Thwapp
Aug 25, 2015 09:54 AM
Bulgin88
Jul 30, 2015 05:20 PM
