help 500 quar master
Old Aug 5, 2009 | 03:26 PM
raybob's Avatar
Default help 500 quar master
my quadmaster will not run unless it has the choke on and there is a bad smell coming from exhaust. it is a 2001, it has been setting for a long time. Ii drained the gas out of it,any help would be app. thanks Raybob
Old Aug 5, 2009 | 08:10 PM
lt230sman's Avatar
hey welcome to the forum!
sounds to me like youve got some gum in the carb. id clean it out real good (soak it in carb cleaner) and re-assemble with a new carb rebuild kit.
good luck!
Old Aug 5, 2009 | 08:12 PM
lt230sman's Avatar
oh and if youre lucky, you may be able to get away with draining the old gas out of the carb bowl (it has gone bad and wont burn, so it just gets pumped out the exhaust and smells bad) by turning the little screw on the bottom of the bowl and letting it drain for a minute, then MAYBE, if youre lucky, things will be fine.
Stirling
Aug 9, 2015 01:49 PM
willday08111217@gmail.com
Technical and How-To Articles
Aug 1, 2015 04:05 AM
Sandman2.0
Jul 21, 2015 09:03 AM
scaldwellk
Jun 19, 2015 05:08 PM
johndjmix
Apr 8, 2000 04:26 AM
