HELP, King Quad 1996 U-joint removal
OK guys, I posted earlier.........I sure need help on how to get the u-joint out of a 1996 king quad 250. I've got the C-clips removed but how do you get the u-joint out.........somebody out there surely has done this before.......how about a hand...........how do those cups come off..........
Well hopefully this will work with an atv cause it works with driveshafts out of cars and trucks sometimes. but take a short well socket smaller then the diameter of the cap place it on one side of the u joint that one of the clips were on, then take a deep well socket slightly larger then the diameter of the u joint cap and place it on the opposite side of the u joint that the other one is on, place the 3 parts in a vice and turn. Spray some lubricant on the u joint first and hit with a rubber mallet to get that penetrating oil in the joints.
Frisky2050
Apr 9, 2020 11:19 AM
