Suzuki kingquad 700
Old Aug 16, 2009 | 03:21 AM
mses's Avatar
Default Suzuki kingquad 700
Hard to start, only wants to idle, wont respond to throttle for ages and dies most times the throttle is used.Eventually after many attempts to rev it up it does start to behaive itself. whats up ? maybe low fuel pressure from pump or what ?
Old Aug 16, 2009 | 06:03 AM
mbogosia's Avatar
You probably already did this, but I always say to start with the obvious. Check/replace your spark plug, and inspect/clean your air filter. Your next step might be to clean out your carb. You would be amazed at the junk gas can have in it.
Old Aug 16, 2009 | 02:23 PM
mses's Avatar
Default kingquad 700
Already done sparkplug and airfilter. And its fuel injected so no carb to worry about although in saying that I would rather have a carb as they are easily fixable in cases like this. So still a mystery !
VABrute
Jan 6, 2016 07:39 PM
clscott84
Sep 21, 2015 10:16 AM
merryman
Sep 19, 2015 03:15 AM
jsmit116
Sep 18, 2015 10:34 PM
Sep 1, 2015 11:59 PM
