no fuel
Old Aug 27, 2009 | 09:55 AM
barkersrock's Avatar
Default no fuel
so i just picked up an 89 lt250 and it ran fine the 1st 2 days,,,,,,,,,
now it doesnt seem to be getting fuel ,, i cleaned the carb,,but 1 out of 100
kicks itll fire ,,,when it did fire it ran like a bat out of hell ,,, rode it,,,,,shut it down then went to start it again and nothing !!!!!!!!! HELP !!!!!
Old Aug 27, 2009 | 01:08 PM
adjusted floats and no change!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Aug 27, 2009 | 01:16 PM
scootergptx's Avatar
Supersock
Hired Gun!
Welcome to the forums.
When you say no fuel, is there any fuel getting to the carb? Is the bowl dry?
Checked for any holes in the diaphram?
And you're sure it's a fuel issue and not a spark issue?
Hopefully someone that has or has had one will get you a better answer.
Old Aug 27, 2009 | 01:21 PM
fuel gets to the carb,, but no further
Old Aug 27, 2009 | 01:28 PM
Supersock
Hired Gun!
I'd take a closer look at the diaphragm.
Old Aug 27, 2009 | 03:33 PM
diaphram ??
Old Aug 29, 2009 | 09:06 AM
Dazeys's Avatar
Can't wait to feel that 130 HP at the dunes.
Pull the plug and see if it is wet and check for a good strong spark. Put in a new one, kick it several time and check the plug again for fuel. If these quad get flooded they are a bear to get started with the kick starter, try to tow it in 2nd or 3rd gear.
ltrmc02
Aug 22, 2021 02:34 PM
SureCanUSA
Sep 14, 2015 09:57 AM
PrairieDog126
Sep 12, 2015 06:53 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Elkaholic
Sep 6, 2015 02:44 PM
