When Changing brakes on my Z400
Old Sep 14, 2009 | 09:38 PM
titanesso's Avatar
Hi guys, I have the same problem, but stil I am unable to squeeze-in the piston a little more, I remove the lever for the emergency brake, but still doesn't want to go back.. I try to unscrew/nut behind the cylinder but is tight like hell. Any tricks on how to back out the screw, I put WD-40 and hope that helps. But let see. Also in the middle of the piston there is like a circle pad that came off, I assume that is to keep dust away from the piston should I glue it back?
Thanks for your help
Gerardo
Old Sep 14, 2009 | 10:20 PM
JBSportTrim's Avatar
Ok yeah I know what yur talkin about...that pad thingy was on mine too, I just placed it back on there...was it supposed to be glued, idk either way its not coming out. Ill have to see if I can back that bolt out....I didnt really put a lot of effort into trying to move that bolt but when I was messing around with it, it was pretty tight and just moving the springs back and forth but not loosening up.
Old Sep 15, 2009 | 12:27 AM
hebo's Avatar
Did you loosen the locknut at bottom of bolt?
Old Sep 15, 2009 | 12:34 PM
titanesso's Avatar
Thank you guys for replying; I believe(Hebo) I know which locknut your talking about, It is pretty hard to remove, I finally got ther pads to go in by removing the emergency brake, however When I put the E-brakes back again, The screw compress the piston and locks the tires... I will keep trying, I let you guys know the final outcome.
Thanks again!
Old Sep 15, 2009 | 09:45 PM
  #15
titanesso's Avatar
Well guys, the final outcome was that I had to remove the parking brake; When I took apart, one piece was broken and I believe, on top of that when I remove the whole pieces, I still can't adjust the screw(bolt). So far I tested the quad whitout parking break and it is breaking ok. I will investigate more to see if it is worth it to replace the parking mecahnism.
Thanks guys again.
Gerardo
Cummins Driver
Sep 11, 2019 01:22 PM
Stirling
Aug 9, 2015 01:49 PM
SixSpeed5
8
Aug 2, 2015 05:38 PM
Jul 15, 2015 02:07 AM
yambam13
Jul 4, 2015 01:49 PM
