New LT230 (to me) Few Questions!
Old Sep 29, 2009 | 07:55 PM
  #31
lt230sman's Avatar
Originally Posted by LT230KiNG
That brotherhood is sweet! Some guys parting out his bike! haha i definitely need plastics.
ok, mine looks exactly like that (cam pic). But when you rotate it, the "U" on the cam is also directly beneath it, like when you rotate it the cam is exactly upside down, its hard to explain. Ill take a pic. So does this mean my timing is on? Because those little hash mark lines stay level with the head....
I went back and got directly on......But when i reset the timing, i made the two hash marks level and put that "U" on the cam down, not up like in lt230smans pic
just a thought, but a 4 cycle engine should run perfectly if its exactly 180 degrees out of time as long as it has a spark discharge on every rotation, no?
Old Sep 29, 2009 | 08:26 PM
  #32
bashr52's Avatar
In a word, No.
Old Sep 29, 2009 | 08:45 PM
  #33
LT230KiNG's Avatar
lol well i tried getting it started witht he timing set with the U up and the U down....
Im guessing i just have incorrect valve adjustments. I got a manual coming, should be here tomorrow....
is intake .003"? and exhaust .005"?
I dont have a mm feeler gauge
Old Sep 29, 2009 | 09:01 PM
  #34
bashr52's Avatar
yes 003 and 005
Old Sep 29, 2009 | 09:20 PM
  #35
LT230KiNG's Avatar
just realized. My timing is 180 degrees off. Because i flipped the timing thinking i had it upside down and thats why i had no spark. But i went through the harness with that wiring diagram and found my constant power wire unplugged. Had strong spark after. Ill go flip it back.
YEAH!!!!!!!
If this is it ill be very proud that i almost figured this out myself lol
Old Sep 29, 2009 | 11:04 PM
  #36
lt230sman's Avatar
Originally Posted by bashr52
In a word, No.
wait a minute, my bad, i just caught myself haha. i meant 180 degrees of cam rotation but then i just realized that it actually doesnt matter since theres no way to tell when youre installing the cam lmao
Old Sep 29, 2009 | 11:34 PM
  #37
LT230KiNG's Avatar
nvm timing was perfect. valves will be checked tomorrow
Old Sep 30, 2009 | 04:08 PM
  #38
bashr52's Avatar
It still matters. If the cam is installed 180 degress out, it wont run.
Old Sep 30, 2009 | 05:57 PM
  #39
lt230sman's Avatar
WOW i just caught myself again. i was thinking of 360 degrees. wtf. what an epic waste of time hahaha
Old Oct 3, 2009 | 05:42 PM
  #40
LT230KiNG's Avatar
Got it running. The power connector thing from the alternator was all dirty, so some wd40 came in handy. Fired right up.
But......it backfires and the choke does nothing.
Backfiring is ignition timing or its running lean right? Im running a uni filter straight off the carb. But i didnt go up on the main jet. I think it still has the stock jet even though it was bored and the filter is being ran.
Could that be it?
Thanks guys!
lonerider856
Oct 13, 2023 03:45 PM
EIF
Apr 20, 2017 07:15 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
