WHAT IS A COUNTER BALANCER ????
Old Feb 25, 2001 | 12:23 AM
bmxatv10's Avatar
Hi, i've heard people talkin about counter balancers, and i was wondering exactly what they are, i know that dirt bikes don't have them, and they have something to do with vibration, why don't dirt bikes have them????
ThAnX!
Old Feb 25, 2001 | 06:09 PM
groundhawg's Avatar
Hey A counterbalancer is a second shaft connected to the crankshaft with opposite weighting to reduce vibration. they have to be timed right also. I suppose they would also give more flywheel effect. Some dirt bikes do have them. I have never seen one on a 2-cycle. Only 4-cycle engines. A multi-cylinder engine has no use for one. Each cylinder counterbalances the other. Hope that helps.
Old Mar 1, 2001 | 05:59 PM
dakotart's Avatar
They are used in multi cylinder engines. Mostly 4 cylinder car engines to smooth them out. Lots of GM's and Dodge/Mitsubishi's and Nissans use them. Hot rodders down here remove them to decrease reciprocating weight of around 10-15 pounds or more. Also less air bubbles in the oil. They work well in single cylinder 4 strokes because the engine basically acts like a very out of balance tire on a car. It will shake like crazy! They rob a bit of power but you won't mind being able to keep the feeling in your hands and rearend.
Old Mar 1, 2001 | 06:52 PM
girthyguy's Avatar
2 stroke engines have them. Look at the arctic cat thundercat. Its a 2stroke 3 cylinder engine.
Like said above the main reason is to smooth out the engine.
matty
Old Mar 1, 2001 | 10:54 PM
bmxatv10's Avatar
Yo, Girthguy ru u talkin about a sled engine, cuz im talkin about atv and dirtbike engines cuz i don't know af any atv with 3 cylinders!.......lol
and Yo Groundhawg, i asked some body if u could put an RM250 engine in a quadracer 250 and they said that they weren't sure if it had a counterbalancer or not, so im figuring the quadracer 250 has one and it is a 2 stroke ! ????
THANX
Old Mar 2, 2001 | 12:32 AM
btodd's Avatar
Most dirt bikes don't need a counterbalancer while many atv's do because of their general geometry. The 4-wheeled atv acts as a better achor to the ground thus allowing a "build-up" of vibration so to speak. The length-without-girth of the motorcycle and the direction of rotation of the crank relative to the length of the dirt bike provide a situation where vibrations are not felt as readily.
Johnny Mac
Aug 15, 2019 03:13 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
TeamGreen
Oct 25, 2000 10:50 AM
250rampage
Jul 14, 2000 12:11 AM
