94,ltf 250?
Old Dec 20, 2009 | 07:58 AM
akarotten's Avatar
Default 94,ltf 250?
I,d like to remove carb to clean on a ltf250,94 mod,see the carb right near top under seat.Is it nessessary to remove plastics to remove it and is it a job for an old man,aint afraid to clean it if i can get it out without a lot of headaches!Thanks.
Old Dec 20, 2009 | 10:15 AM
NewportHillClimber's Avatar
no its not bad to do. youll have to undo airbox clamps on back side of carb and intake clamps on front side then twist it out and undo your throttle cable and choke cable. you may want to drain gas out of carb with drain screw before doin this so you dont get gas all over your leg when you pull it out
