1985 lt250 won't run
Old Dec 30, 2009 | 01:11 PM
sjarensky's Avatar
Question 1985 lt250 won't run
Hey all,
I bought a 85 lt250 used. The motor would start and run fine until I took the air box out to clean and check everything. Once I put everything back the bike would start only with the choke on and will not rev.
I checked all the wiring and everything looks tight and clean.
I noticed a small switch on the back of the motor with 3 blue wires. Two go to the wiring harness and one goes into the stator cover. The wires look a little frayed. What is this switch and does anyone have any idea what else I should check?
Old Dec 30, 2009 | 04:29 PM
NewportHillClimber's Avatar
which lt250 is it? is it a lt250r or a utility?
Old Dec 30, 2009 | 04:49 PM
sjarensky's Avatar
Smile
It's a LT250r
After some more fiddeling I think it's got dirt in the carb. I can pull with the choke all the way on and it'll run for about 3 minutes. If I take the choke off or try to give it gas it begins to sputter and wants to die. If I start it 3 or 4 times it gets to the point where it'll just fire up and die withour running at all.
I thought I did something or FUBARed something when I took it apart, but now it looks like dirt got in the carb and it's my luck it happened when I was F**king with it.
Dammar
Aug 26, 2015 07:12 PM
Dustinyoungs
Jul 24, 2015 07:18 AM
CRamshaw777
Jul 18, 2015 05:46 PM
HondaR24
Jul 16, 2015 10:45 AM
scaldwellk
Jun 19, 2015 05:08 PM
