Carb Help Please
Old Jan 23, 2010 | 10:10 PM
  #21
cwd09's Avatar
Originally Posted by trailblazer250racer
did you try going to a local parts store possibly they could tell you.
i am goin to when i have time. i work alot. :/
Old Jan 23, 2010 | 10:58 PM
  #22
Rucsak's Avatar
Default Loosen tight screws - tip
With my past working on cars also working around the house the best way to deal with tight screws is often, givening the screw a turn in the direction to tighten then loosen obviously the other way. If possible a couple of gentle taps on the end of the screw driver with a hammer or an impact screw driver & turning at the same time. Extremely rusted on bolts can use WD40 & leave for a while. If unsuccessful we often need to use a little heat ie a gas plant - although we do need to consider the location & what can & can't be heated. Don't forget the tap & die set when the screw was drilled out, therefore making the hole wider than before. Just a thought for those that may not know.
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
