Hard starting 1985 LT230 GE
Old Feb 7, 2010 | 09:26 PM
advnchr's Avatar
Default Hard starting 1985 LT230 GE
My LT230 GE Quad is extremely hard to start when temps are below 50 degrees F. Winter starting, I need starting fluid to get it to fire. Once it is warm it runs OK. Any help would be of great appreciated!
Old Feb 20, 2010 | 07:20 PM
86qscamo's Avatar
hello i currently own i an 85 230 quadrunner and mine was hard starting also, i simply adjusted the valves and overhauled the carb, it cost me 20.00. if you think it may be fuel related install a clear section of fuel line somewhere in the fuel inlet if its not getting fuel, dont buy a new fuel pump or used or a rebuild kit they are all too expensive they are made by mikuni get a new one from these guys 20 bucks www.jcspecialty.net its the same unit,i raced karts for years these guys are great
Old Feb 22, 2010 | 09:17 AM
advnchr's Avatar
Thanks. At least I have a place to start with. As far as the valve adjustment, I'm not sure on the specs or procedure (no longer have manual). Any tips would be great.
Old Feb 23, 2010 | 12:49 PM
kidcurry's Avatar
Smile I have the book
You can see the problems I am having in my post,just let me know what you need?
Old Mar 4, 2010 | 12:04 PM
advnchr's Avatar
Default ATV valve adjustment
Any procedure tips on adjusting the valves would help (specs included).
Thanks
MikeyBoyesq
Nov 27, 2020 02:44 PM
chinkapin
Jul 14, 2016 06:58 AM
Shooterj2003
Jun 21, 2015 07:51 PM
scaldwellk
Jun 19, 2015 05:08 PM
1000gade
May 27, 2015 12:37 PM
