lt-z400-2006
Old Feb 9, 2010 | 06:34 PM
lblower813's Avatar
Default lt-z400-2006
i have this problem , when shift to reverce and acelerate the engine start missfire but shift back to first shift , runs fine. anyone can help?
Old Feb 9, 2010 | 07:04 PM
TRX1000's Avatar
that might be your reverse limiter? so you only go a certian speed in reverse.
Old Feb 9, 2010 | 07:50 PM
spize909's Avatar
Yep, it's the reverse rev limiter. It's supposed to do that. Do a google search for "disable reverse rev limiter" and you should be able to find out how to manipulate a couple wires to eliminate it if it bothers you enough.
Old Feb 9, 2010 | 11:05 PM
2strokezilla's Avatar
yep reverse limiter sometimes it can affect 1st gear tried to eliminate it but blew the fuse gave up on that
