05 z-400 suspension set up
Old Mar 2, 2010 | 02:44 PM
ajetmech's Avatar
Default 05 z-400 suspension set up
I just picked up a 05 z-400 for my son. I found info on how to set sag which we are going to do this weekend. I could not find anything on what the stock settings are for the front and rear comp and rebound. The guy we got it from messed with the settings and it swaps pretty good going through the whoops. I don’t have a book for it yet. (been searching online for a free one) any help will be appreciated.
Old Mar 3, 2010 | 05:36 PM
ajetmech's Avatar
Anyone???
Old Mar 19, 2010 | 03:35 AM
amcf18's Avatar
i am a light rider, 140 lbs, and run no compression damping on front and rear, trying to get the softest ride.. also have the preload at minimum. You can add rebound damping to try and slow the rear end kick up..I dont moto mine,so cant tell you exactly what you need..front shock= rebound is all the way in, then out 1 1/2 turns compression all in, then out 1 3/4 turns, for stock setting
rear=rebound all in, then out 1 1/2 compression, all in, then our 2 full turns
these are the stock settings...If you are motox you might end up going with a widening kit to make it more stable?
Old Mar 20, 2010 | 05:07 PM
ajetmech's Avatar
Thanks
Robinhood
Dec 26, 2015 10:28 AM
bigred20653
Sep 19, 2015 02:11 PM
chewy78
Sep 8, 2015 10:37 AM
Nekolai1
Aug 25, 2015 10:04 PM
Mssarabug
Aug 10, 2015 12:56 PM
