eiger stalls in water
Old Mar 26, 2010 | 01:48 PM
RonV's Avatar
The hose that comes off the top of the carb needs to be wormed upward and then hooked into that little hole at the base of the fuel tank cover, but under the seat. Right next to the little black air snorkle that comes out of the air box. Mine was dangling down and if I went into deep water for any period of time it would stall out. You may want to check that, cause I had the exact same problem you had. Easy fix.
Old Mar 29, 2010 | 09:47 AM
sled ed's Avatar
I found mine hanging down and have rerouted it like you said. i just have to try going through water again
Old Mar 29, 2010 | 04:05 PM
Phonce's Avatar
I have a 250 qeadrunner and it quits when the watea gets over the plug . The problem was the plug cap.
Old Apr 3, 2010 | 12:23 AM
RonV's Avatar
Excellent. That should fix it. Make sure that line doesn't get kinked as that will make it stall out, too. My brother-in-law's Eiger had that problem and it took me cleaning the carb three times before I figured it out.
Old Jul 10, 2013 | 04:07 PM
  #15
bud410's Avatar
Had to sign up to thank you for the help. I've got an 03&04 eiger 400. Went riding with friends and the 03 stalled out in shallow water. Went to the extreme and flooded the engine with a large hose trying to get it to stall. After reading your post I had it fixed in 15 minutes. The hose on the Carb was routed out the bottom of the fourwheeler causing it to get blocked off in shallow water. Now it is routed up under the seat. Thanks again.
Old Jul 10, 2013 | 05:26 PM
  #16
RonV's Avatar
Glad I could help!
Pehter
Oct 3, 2024 11:00 PM
Customer Service #1
May 15, 2020 08:46 AM
Alex G.
Sep 11, 2017 11:38 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
