Quadmaster 500 cv boot replacement
Old Mar 19, 2010 | 01:55 PM
93truck's Avatar
Question Quadmaster 500 cv boot replacement
I am in the need to change two boots on my front axle. one inner and one outer os separate sides. i have removed everything except the cv shaft. My problem is that i cant figure out how the shaft comes apart. i know theres a clip on the inner shaft but its inside the diff case. Can anybody shed some light on this subject. Just a little bit of info will go a long way on this problem. My bike is a 2000 if it means anything.
Old Mar 23, 2010 | 03:57 PM
NottinghamRider's Avatar
On most quads to release the shaft you just press the shaft in (towards the center of the quad) then quickly give a firm tug outward and it should come out.
Pressing in is supposed to compress the clip, and the swift pull out should allow it to come out for maintenance.
toonces
Aug 6, 2015 10:46 AM
toonces
Aug 5, 2015 05:55 PM
toonces
Jul 28, 2015 01:58 PM
TLC
3) General Discussions..
8
Jul 26, 2015 11:09 AM
TLC
Jul 25, 2015 02:24 AM
