96 king quad 300
Old Mar 31, 2010 | 08:42 PM
jayman485's Avatar
Default 96 king quad 300
I have put a carb kit in my 1996 300 KQuad because it wouldn't idle. After the install, the bike would rev up then down on idle. I figured air leak. I replaced the plastic boot, gasket, and o-ring on the machine intake side due to a small crack. It has since gotten worse. It lacks power and is back firing now. Compression is 135psi, no leaks, the misture appears good, a visual by the plug. I installed a inline high flow fuel filter. I am stumped. is it possible that the timing could be off. I set the main jet 1 1/4 turn. any thoughts on this matter you help pls.
Jay
Old Apr 2, 2010 | 10:58 AM
faruquehabib's Avatar
is the idle screw adjusted correctly?
Frisky2050
Apr 9, 2020 11:19 AM
Ashley S
May 29, 2017 10:54 AM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
DOC HOLIDAY
Jul 9, 2015 01:09 PM
D-Hagz
Jul 4, 2015 02:19 AM
