old suzuki trouble?
Old Apr 13, 2010 | 09:21 AM
4wheeler dude's Avatar
Default old suzuki trouble?
hello everyone, 4wheeler dude from pennsylvania,i have a 1985 lt 230s suzuki. when it gets warm it wont idle,im having a hard time figuring it out ,and want to know if anyone else has had this problem,or if anyone can give me any ideas where to look. i have checked the carb,coil cdi,and they all seem to be fine.will the stator make it act like this? any suggestions would be greatly appriciatedthanks again 4heeler dude in PA.
Old Apr 13, 2010 | 09:48 AM
gbflex's Avatar
Check all your rubber boots for air leaks, did you trying adjusting the air idle screw? Its the larger brass screw on the left side of the carb. Turn it counter clockwise until she idles. You may have something in your pilot jet 2, that will cause your problem. Also check all your grounds. Good Luck!
Old Apr 13, 2010 | 10:28 AM
i have checked all that? im stumped..........
Old Apr 14, 2010 | 09:49 PM
Motomanmike's Avatar
Default Check valve clearance
Might be getting a tight valve at full temperature. Check them to make sure its not tigtened up over the years. I've seen it happen a few times.
95wolv
Sep 27, 2024 12:00 PM
mrtidy
Feb 3, 2016 05:00 PM
Clint Russell
Sep 25, 2015 03:20 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Sep 1, 2015 11:59 PM
