broken air screw need some help!!!
Old May 3, 2010 | 09:31 PM
jayman54's Avatar
Default broken air screw need some help!!!
i finally figured out my idle issue with me bike. after seeing another thread and checking i found the very tip of my air screw broken off in my carb...now i gotta figure out how to get it out... i'm gonna try air but i have a feeling its not gonna work...
Old May 8, 2010 | 11:20 PM
spize909's Avatar
nope that won't work.
If you haven't found it already do some searching. You should be able to find a description of how to do it by using a broken needle, a pair of needle nose vise grips and a hammer.
You basically punch it through.
I bought a used FCR 39 for my z400 and the tip was broken off in it. I put my carb in the freezer for a while before doing it. That was either in that write-up or something similar.
There are those that will say your carb is junk. Not necessarily true. Mine works fine now.
ReconBayou
Oct 31, 2022 05:37 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Beeline08
Nov 11, 2016 04:00 PM
Oct 10, 2015 10:20 AM
Jackg17
Sep 26, 2015 09:30 PM
