Help with 84 250 quad runner
Old Jun 19, 2010 | 06:58 AM
bowhunterjohn's Avatar
Default Help with 84 250 quad runner
Hey everyone, thanks for looking and helping
here is the issue
I have a 84 250 quad runner, bought it years ago to help around the farm, hunting and trapping.
I have been fouling spark plugs really bad, like in an hour of using the thing. I check out the choke cable and it was fried, so I cut it off and " rigged" up a system so it is workable again.
What happens is that when its hot out I'll run it for a while and then it dies out and won't start. If you let it cool down it will start again.
There is very little gas in the new see through filter I installed last year, however when you pull the plug it is black with soot/carbon build up. Clean it off , or put in a new plug and it will start.
The head has a slight oil leak on the outside around the compression release.
I am mechanically inclined as I raced motocross for many years , so I know how to work on the thing.
Don't want to spend any money on a newer one as I take this one through brush and stuff and its not very nice looking, and hate throwing something away that could be useful
ANY HELP IS APPRECIATED
Old Jun 19, 2010 | 03:04 PM
kiljoy250's Avatar
The oil in the head is fouling out your spark plugs. Try replacing the valve stem seals or adjusting the valves.
Old Jun 21, 2010 | 10:04 AM
himsa169's Avatar
my 230 sport did similar stuff with fouling plugs and dying after 10 mins of riding and i just put a new top end in cuz the machine is just old but it still had good compression i just did it before anything happened and i had the leak on the compression release to so when i pulled my motor off the frame the exhaust was caked with burnt oil and carbon the head was also with serious carbon build up so i cleaned it all up sprayed my compression release with brake cleaner and silaconed it i have no problems and hasnt leaked at all but cost 100 with me doing all the work including the porting and cleaning, and my friend had a hone i could barrow but you dont have to port it if you dont know how. good luck
skinnyr6
Aug 25, 2023 02:18 AM
Frisky2050
Apr 9, 2020 11:19 AM
Ashley S
May 29, 2017 10:54 AM
vlkster
Jul 28, 2015 11:35 AM
Chillibean
Jul 26, 2015 09:47 AM
