Oil Change - LTZ440
Old Jul 3, 2010 | 11:01 PM
Soulphire's Avatar
Default Oil Change - LTZ440
Changing the oil in my 2006 LTZ440 (BBKit). I bought some Mobil 1 0W40 because I have heard of people using it in their 4x4 ATV's. Is this safe for this machine as well? Or does it need something else as this is a higher revving engine.
Thanks in advance.
Old Jul 4, 2010 | 12:42 AM
hebo's Avatar
Thanks in advance.
You should not use oil unless it says atv.Your atv is using a wet clutch (your clutch sits in oil) Regular motor oil can mess that up detergents ,ETC .10-40 is what the book calls for Also these motors are thumper type (short stroke) you need a oil that can handle that.
Old Jul 4, 2010 | 01:28 AM
blindside350's Avatar
More or less right, as you do not want to run Energy Conserving spec'd oil in wet clutches. However Mobil 0w40 is not energy conserving, but I believe its designed for Euro cars (VW 502 spec?), which has who-knows what in terms of additives. If I were you I wouldn't run any syn or syn blend oil without it being designed or ATV/MC.
Castrol GTX is always a solid fall back dino oil
Old Jul 4, 2010 | 02:17 PM
NewportHillClimber's Avatar
suzuki recommends suzuki 4 motor oil or any equivalent 10w40 with a minimum rating of sf or sg. i wouldnt use 0w40 in any atv
Old Jul 4, 2010 | 08:20 PM
Doctorturbo's Avatar
GOT BOOST!
You will be fne using your Mobil 1. It's great oil and fine for your ATV.
Old Jul 6, 2010 | 04:32 PM
2strokezilla's Avatar
here we go again with the oil choices its your engine and your pocketbook if its the wrong oil 1.suzuki tells you what oil to use 2. its a motorcycle engine with a wet clutch not your automotive engine. 3. sure m/c oil is alot more money
nuff said
Old Jul 6, 2010 | 07:00 PM
u can use mobil 1 but i would use 10w40 and check the rating. im sure its well over sf or sg but look to make sure
Old Jul 7, 2010 | 01:55 AM
beart0y's Avatar
Smile
Have used Mobil 1 for years in Motorcycles of all sizes. Both manual and auto clutches. Never had a worry.
I feel that the Oil companies duck for cover behind a wall when they hear of a DIFFERENT application. Unfortunatly the U.S.A. has a reputation of litigation and this holds back too many from doing things.
Viscosity should be what the manufacturer recommends. Stick to that.
Old Jul 7, 2010 | 11:57 PM
Soulphire's Avatar
Ok, I made a mistake...Ugg! The oil I just used is Mobil 1 0W30, NOT 0W40. Should I drain it and replace it, or is this okay until the next oil change. I ride in the mountains of Colorado, so when I start the ATV it is somewhat in the 40-50 degree range outside.
Thanks.
Old Jul 8, 2010 | 12:56 AM
TLC's Avatar
TLC
according to this Mobile1 is made for wet clutches. I hope so I never seen a street bike NO wet clutch.LOL
Seems to only come in 10w-40 or 20w-50. Your 0w-40 may not be for wet clutches as mentioned,read the lable.
Mobil 1 Motorcycle Oils
ReconBayou
Oct 31, 2022 05:37 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Alex G.
Sep 11, 2017 11:38 PM
Gwolf228
Feb 18, 2017 01:36 AM
Jackg17
Sep 26, 2015 09:30 PM
