LT-F250 no top end rpm, hot regulator at idle
Old Jul 7, 2010 | 07:33 PM
connella08's Avatar
Default LT-F250 no top end rpm, hot regulator at idle
my friend brought me his quad to fix an oil leak and i found that he has no top end power. it is an 04 LT-F250 quadrunner ozark. i can push the throttle in about half way and it responds with minimal lag but the rpms stop going up even if i continue to push the throttle in the remainder. i let it idle for about 5 minutes on a cold start and noticed the regulator was hot to the touch and is charging at 15v AT IDLE. stator is fine and cdi i believe is fine but does it sound like the regulator is bad and can this be the cause of a lack of top end RPM's?
Old Jul 8, 2010 | 02:07 PM
connella08's Avatar
i typed this thread while i was tired and realized i can sum it up in one simple question.
is my voltage regulator bad if its charging the battery at 15V at IDLE?
Nosniborpapa
Sep 12, 2015 05:54 PM
zPuls3
1) Engine problems..
Sep 12, 2015 08:54 AM
Minimod
Sep 10, 2015 09:20 PM
Hw00d
Sep 10, 2015 08:53 AM
Minimod
Sep 10, 2015 08:03 AM
