quadrunner lt230e clutch side case cover
Old Jul 12, 2010 | 05:22 PM
redneckmotorhead's Avatar
Default quadrunner lt230e clutch side case cover
i cant for the life of me get the clutch side crank case cover off this bike, ive never worked on one before so i imagine im doing something wrong, i've removed every nut and bolt but it wont budge more then an 8th inch. help would be wonderful
-b
Old Jul 13, 2010 | 04:29 PM
bloateus's Avatar
did you remove the screw where the oil filter is, also did you remove the clutch lever?
Old Jul 27, 2010 | 12:10 AM
Scottie_The_Boy's Avatar
worked on that same cover on my LT230e the other day... I almost forgot the Screw that is on the Right hand side of the cover it's located under that Circle Small Cover which is your Oil Filter Area..Unbolt them 3 screws/bolts and remove the oil filter and inside that Hole there is another small bolt on the right hand side..then it should slide right off, Also Remove the Starter and foot rest and Rear foot brake peddle... the rest should be just bolts...
Scottie_The_Boy
ghost civic
Jan 15, 2020 07:43 AM
SDR-II
Sep 29, 2015 01:06 AM
ghost civic
Jul 15, 2015 10:48 PM
Countrygirl1976
Jul 13, 2015 10:08 AM
Countrygirl1976
Ask the Editor
Jul 13, 2015 12:19 AM
