nerf bars for 1985 suzuki lt230s?
Old Mar 6, 2011 | 01:13 PM
MIsuzukilt230s's Avatar
DG Steel Nerf Bars - DennisKirk.com
@87zuki
They may not bolt up directly as dk says the ones I ordered (link to them above) only fit 85-86 lt230s quadsport. The ones bruin has/had are identical to the ones I ordered and now have on my 85 lt230s. Try going to bikebandit.com and pulling up the frame parts diagram for the 85 230s and the 87 230e and do a stare and compare to see what may be different when it comes to mounting the bars. Good luck and I hope you find a set to work/modify!
Old Mar 6, 2011 | 02:35 PM
snow racer's Avatar
How do they bolt on can you post some picks of them on.
Old Mar 6, 2011 | 04:22 PM
Trailrider230s's Avatar
@87zuki
actually the frames are the same where the footpegs bolt on. only the nose and rear section of frame were lenghtened. so the engine section of the frame is identacle through 85-88. only if you have a 230E frame would i be worried about fitment issues.
Old Mar 6, 2011 | 04:25 PM
they bolt on with 2 U clamps in the front and through the bottom footpeg bolt. also known as the bolt motor mount bolt, thats the bolt that always fails if you're ramping and you feet fall off the peg and land in the netting then the bolt bends.
Old Mar 6, 2011 | 04:34 PM
  #15
snow racer's Avatar
Thanks TR you always help some time this summer im going to order Nerf bars.
Old May 28, 2011 | 06:34 AM
  #16
Bruincat's Avatar
Originally Posted by 87Zuki230E
Hey Bruin, I was wondering if you still had those nerf bars and how much.
Thanks
i still have them. i know its been a couple months since you asked. i guess i should change my email on the forums to an email i actually use. if you still need them let me know.
Old May 28, 2011 | 07:46 PM
  #17
dakbee's Avatar
pm me a price, i may be interested.....my zip is 72846 in arkansas, thanks
Old May 29, 2011 | 01:28 PM
  #18
point29's Avatar
If you had some time and a welder you could make your own for about $30. I was going to do a spider web pattern on the foot platform, But it would have taken a little more time then I had at that time. They work great for track riding just add a tether switch and she's track legal.
Old May 29, 2011 | 04:04 PM
  #19
dakbee's Avatar
Those look nice! I dont have a tubing bender tho
Old May 29, 2011 | 06:19 PM
  #20
point29's Avatar
I didnt use any pipe bender. All the stuff is from home depot. Already
pre-bent pipe just cut and weld together.
