ltr450 engine swap for lt500 2 stroke
Old Sep 8, 2010 | 02:50 AM
Drover's Avatar
Default ltr450 engine swap for lt500 2 stroke
just wondering if anybody would know if its posible to fit the lt500 engine in the new ltr was thinking on doing the build just wanted some info before i started getting into somthing i might regret
Old Sep 9, 2010 | 02:43 AM
dirtjunkie's Avatar
i would not do it, it will get costly and time consuming. Can you weld aluminum ?
Old Sep 9, 2010 | 03:00 AM
Drover's Avatar
dont need to weld aluminum the frame is steel on the ltr as far as i know the only 450 with a aluminum frame is the kawi but i do got a buddy that can weld aluiminum if i need it right now the only thing i need to figure out is how i can move my rear shock its in the way of the carb but i was thinking a plus 2 or 4 swing arm and then move the mount back and it should be good
Old Sep 9, 2010 | 11:39 AM
Dirtjunkie85's Avatar
I have never herd of anyone doing this but it would be pretty sweet, if you got the time and money go for it!!
Old Sep 9, 2010 | 05:14 PM
Sand Hog's Avatar
Moving your rear shocks and or swing arms sounds like a recipe for everything to go wrong at the worst time.
Only in my opinion if it was such a good idea don't ya think Suzuki would have a production LTR500 Quad Racer model out in that configuration by now?
I'll keep my LTR450 Quad Racer in its production specs thank you very much it can be a handfull as it is I cannot think of the concept of why anyone in their right mind would think of removing a water cooled 450cc efi engine and put a 500cc 2smoker in its place.
But Alas its your quad be sure to let us know how it works out for you.
Old Sep 9, 2010 | 06:51 PM
Drover's Avatar
i already got a ltr450 done up but i just bought one that has no engine for $1000 to do a difernt kind of build more less a project i was just think it might be sweet to do so im going to do it over the winter i think it will be a sick build for drags or the dunse not to mention it will turn heads because its not exspected
Old Sep 9, 2010 | 07:08 PM
Drover's Avatar
i also found out i dont need to move the shock i will just need to get a diferent shock because the stock reservoir is is the way so i just need to get one with a piggy back reservoir
Old Sep 10, 2010 | 10:02 AM
Sand Hog's Avatar
Ok now I understand now it sounded at first like you were going to rip out the 450cc engine for the 500cc..
Sounds like a fun winter project, Have fune.
Old Sep 10, 2010 | 10:57 PM
spize909's Avatar
go for it!
I rode a friends quadzilla at Glamis last year......took it up Olds and that thing was way out of control from what I'm use to. Scary fast. Put that motor in a new technology vehicle and it could be sweet..
My buddy has two that they've had since new. One for him and one for his wife. They are in there 50's and ride the dunes for hours. One ride beat the hell out of me......not to mention kick starting the thing.
bzdok1234
30
Feb 23, 2016 01:55 PM
SDR-II
Sep 29, 2015 01:06 AM
Big bousse
Sep 26, 2015 10:42 AM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
Shifts
Jul 3, 2015 07:59 AM
