really need help 93 suzuki king rear brake
Old Dec 9, 2010 | 12:54 PM
lawns90's Avatar
Default really need help 93 suzuki king rear brake
I have a 1993 suzuki king quad 4x4 lt 280. I cannot get the rear hub off to access brakes. I have sprayed wd 40. I really need advise. Thank you
Old Dec 9, 2010 | 10:04 PM
ba300's Avatar
Orginal Trespassers
Is the drum stuck in the center or are the shoes holding it??
Old Dec 10, 2010 | 05:29 AM
lawns90's Avatar
the drums are not stuck. What happens is when you use the back brake lever the brakes will not release. I have to manually realease them using a crow bar on the lever on the back of rhe tire. the wheel spins freely.
Old Dec 10, 2010 | 06:18 AM
ba300's Avatar
Orginal Trespassers
I use a big slide hammer . sounds like the spline is buggered or twisted.
Do you have any tool rental around.
Old Dec 13, 2010 | 12:18 PM
ba300's Avatar
Orginal Trespassers
any updates
Old Dec 13, 2010 | 08:25 PM
Sisco1957's Avatar
Make sure the lever isn't pulled back to far. If You pull it back to far the shoes will expand out. Is the cable loosened off at the foot pedal to let the shoes retract all the way? Your cable may be sticking too.
STLyamwar
Jul 25, 2020 04:44 AM
greg74
Sep 10, 2019 03:03 PM
SixSpeed5
8
Aug 2, 2015 05:38 PM
Sandman2.0
Jul 21, 2015 09:03 AM
timster911
Jul 13, 2015 01:57 PM
