Changing stock piston rings?
Old Mar 14, 2011 | 08:02 PM
point29's Avatar
Default Changing stock piston rings?
I'm rebuilding my first adult quad and need some help with the piston rings for it. The size of the piston hole is 66mm. I did Hone the hole. Would I just get the rings that are 66mm like the ones in the link? Thanks
Suzuki LT230S LT230 QuadSport Piston Ring Set STD 66mm - eBay (item 400201533010 end time Apr-08-11 22:32:42 PDT)
Old Mar 14, 2011 | 08:16 PM
Trailrider230s's Avatar
yup thats the one you need. just make sure they are for the 85 230s that you have. 87 and above are thicker.
Old Mar 15, 2011 | 08:52 AM
LT80's Avatar
LT80 Expert
But is the piston a 66mm?
You get the rings for the piston size, not the hole size.
You may indeed be correct but you better make sure.
Personally, I'd stick a new piston/rings in it.
Old Mar 15, 2011 | 09:03 AM
point29's Avatar
yes the piston is 66mm to.
If the piston is in great shape your still saying to to buy a new one?
Old Mar 15, 2011 | 12:08 PM
everyone does it their own way. if the piston is in great shape i wouldn't. if you re trying to keep cost down i'd just get the rings.
Old Mar 15, 2011 | 07:48 PM
point29's Avatar
Are the 87' LT230s pistons the same as the 85'
Old Mar 16, 2011 | 10:10 AM
LT80's Avatar
LT80 Expert
I've never been a rings only guy.
If the piston has a dull finish, it's wore.
Only real way to make a decision on the piston is to measure the piston to wall clearance. Above .006/.007 and it's time for a new piston.
I just don't want you to get it together and have a problem.
STLyamwar
Jul 25, 2020 04:44 AM
Hankey Pankey
Jul 31, 2015 05:50 PM
Hankey Pankey
Technical and How-To Articles
Jul 29, 2015 10:57 PM
southbayman
Jul 24, 2015 09:30 AM
clsharky
Jul 13, 2015 02:07 PM
