lt 230 help
Old Oct 27, 2011 | 08:41 PM
Foxrider99's Avatar
Default lt 230 help
I just got a 1989 lt230 4 stroke I need help it was rode without a air box or air filter. For how long I don't now. It runs good when I can get it started.. I never owned a quad or a suzuki I was wonder what I meant have to do to make it start with just a couple of kicks? I only way we can get it to fire is tow it or run it down a hill pop the clutch.. Would that be a carb gummed up problem. I was told to it was bored to a 300cc would that make a diffances..
Old Oct 28, 2011 | 07:10 AM
If you haven't already done so, you need to ask this question in the Suzuki section to get more answers.
Old Oct 28, 2011 | 07:30 AM
LT80's Avatar
LT80 Expert
I'd check the compression then valve lash.
Without a air filter the dirt ruins the piston/etc.
Old Nov 1, 2011 | 08:49 PM
NewportHillClimber's Avatar
does it have the airbox and filter now? and it may be something as simple as adjusting the carb once the airbox and filter are correct.
Old Nov 2, 2011 | 07:57 AM
dog walker's Avatar
without airbox and filter it would be too lean and very hard to start.
