1986 suzuki lt 250R model type?
Old Oct 29, 2011 | 11:29 PM
2speed1970's Avatar
Default 1986 suzuki lt 250R model type?
Hello,
I am new to the boards and I am restoring a 1986 LT 250R and would like to know the difference between the F model or G model. Just so I get the right parts ordered. And if anyone would know where the best place to order parts for this 4 wheeler, as far as to resore it using the oem parts etc. Thanks. John
Old Oct 29, 2011 | 11:48 PM
95wolv's Avatar
I googled LT 250R and got a parts fiche for the different models, every part was either F/G or the others H/J/K/L/M/N , so it would seem any F or G part is pretty much the same. The other models even had an exhaust vavle, so maybe those had some kind of variable exhaust valve like a snowmobile for more power. even the exhaust is different on the F/G compared to the other models.
Old Oct 30, 2011 | 10:51 AM
2speed1970's Avatar
Thanks for the info, I've serched for the answer on google and everything, but I couldnt get a clear answer on the differences other than what you came up with. I thought maybe it was F=1985 and G=1986 ??????.
Old Oct 30, 2011 | 07:53 PM
jgar's Avatar
Iam no 2 stroke expert... But I think it may have to do with the location or style of the reeds. I was told the first year of the zuki r's there was something strange with the reeds that made them seem a kinda gutless compared to other years.
Old Oct 30, 2011 | 08:22 PM
95wolv's Avatar
Probably a case reed set up like the older snowmobile engines, while the newer models (H on up ) show an exhaust valve set up in the parts fiche, probably a variable exhaust power valve that picked up the performance.
Old Oct 31, 2011 | 04:35 PM
Scooter86's Avatar
Knows Old ATV Questions!
The F/G is for model year. There was no significant difference between them that I am aware of. For the '87 model year, Suzuki switched from the case reed trail bike motor to an RM style motor with a powervalve. The frame and suspension were all somewhat different as well.
Old Nov 1, 2011 | 08:21 PM
NewportHillClimber's Avatar
f/g 85-86 are the same. 87 was its own engine. and the rest engines are the same. i had an 86 and have worked on several of them. if u need to know anything maybe i can help
1986Vmax540
Jul 9, 2021 09:53 PM
Backwoods_badass
Aug 2, 2015 10:40 PM
JoAnnS
Jul 23, 2015 02:18 PM
CRamshaw777
Jul 18, 2015 05:46 PM
