Lt80 help!!!
Old Feb 7, 2012 | 06:07 PM
cstrait37's Avatar
So if I can get a carb rebuild kit and an on/off petcock, I should be headed in the right direction. Yes? Again, my experience with this machine (and two strokes in general) is limited at best.
What would I do with the vacuum tube w an on/off petcock? Does it serve a purpose with that ****?
Old Feb 7, 2012 | 07:08 PM
cstrait37's Avatar
So carb rebuild kit and petcock with an on/off switch. What would I do with the vacuum hose off the carb?
Old Feb 7, 2012 | 09:03 PM
cstrait37's Avatar
Ok. 10 pm as promised. Spark=constant blue. Thanks lt80pilot.
Took off all plastics. Blew out EVERY connection. Used dielectric grease on all connections.
Started her up.
Took 10 good starts (of about 5 seconds each start). Again, I know that's not good for the starter. Whatever.
Fired up. No noticeable difference. Except I started in the RUN position with NO CHOKE and full throttle. Did not go to PRIME position. And... No puddle.
My carb kit is coming Thursday. I have until then to search for a good petcock. ANY SUGGEsTIONS?
PRAYING a carb kit and a petcock will take the years away from my little guy and we can ride on Friday. This is killing both of us.
Thank you SO much lt80 and lt80pilot!
Old Feb 8, 2012 | 07:42 AM
cstrait37's Avatar
PRAYING a carb kit and a petcock will take the years away from my little guy and we "can ride on Friday."
That shold have read: TEARS away from my little guy... And this is taking YEARS off of my life.... Can't thank you all enough!
Old Feb 8, 2012 | 09:01 AM
  #15
270quadsportguy's Avatar
Also you could shut off the gas and let it run for a min or two to run the float bowl out. Always makes for easier starting especially when running mix
Old Feb 8, 2012 | 10:22 AM
  #16
cstrait37's Avatar
I will do that next... See if that cures a problem... Let you know when I get it done tonight... Thanks 270!
Old Feb 8, 2012 | 07:23 PM
  #17
LT80Pilot's Avatar
That port off the carb for the petcock can just be plugged with a short piece of hose with a screw in it, maybe with a lil RTV sealant to ensure it's does seal. I was going to J-B weld it shut (like I did with the oil injection port) but I will probably go back to an OEM petcock if that ON-OFF-RES petcock turns out to be trouble. I think my 9 year old is going to forget to turn it off after each ride.
Hopefully your son can get a lot of hours on it before you have to do the ring job to fix the compression, prob being just a tad slower can't hurt when he's only 4. Take care
Old Feb 8, 2012 | 07:58 PM
  #18
cstrait37's Avatar
Lt80pilot. What are the chances I leave the **** stock and put the on/off switch after the **** and before the carb? Will the fuel switch work there?
Old Feb 8, 2012 | 09:41 PM
  #19
LT80Pilot's Avatar
Yeah, I believe that's what LT80 was saying, but the valve between the petcock and the carb.
I believe you just leave it on PRI (prime). As long as fuel is coming out when you turn the valve to ON, you are good.
Old Feb 8, 2012 | 10:15 PM
  #20
cstrait37's Avatar
couldn't find any at 3 stores today... going to get one tomorrow... rebuild kit in tomorrow... after all is put in place tomorrow night, i will give some more feedback from our original suggestions...
i guess from here if it doesn't work, i'm looking at tp end rebuild... has to happen eventually but that wont go over so well, so i am praying this is a fix and i can do the top end in a bit... thanks everyone, check in tomorrow...
